doctorchris
Established member
Well, we have about 3 years experience of the new Panda available on this site. He have Panda faults spread out over numerous threads. How about collating them here.
I will start with the faults I have experienced on my 4x4 which I purchased new in July 2005 and which has now done over 18,000 miles.
1. Rubbing strip on front nearside door came away, replaced under warranty.
2. Failure of electrical boot release mechanism. A common fault due to failure of a microswitch but repair entails replacing the whole boot catch mechanism which also has to be painted to match the car so a long-winded repair. Again repaired under warranty.
3. Found that one of the bolts holding the outlet manifold heatshield had disappeared. Fitted a new bolt myself but some cracking of the heatshield around the site of the missing bolt which I need to keep an eye on.
4. Water inside nearside headlamp . My fault for pressure washing inside engine compartment so I dried the unit out with a hairdryer and kitchen towels.
5. Corrosion of offside front wiper arm which I will bring up at next service.
6. Both side repeater indicator units fill with drops of water. I know others have had these replaced under warranty, but I can't really be bothered. Do the replacement units let in water or is the problem cured?
Basically these are all fairly trivial and I have given the car a hard time including touring in France and some proper off-road use so I'm pretty plesaed with it. I don't see why Pandas should not give over 10 years reliable service if properly maintained.
