have any one come accross this problem
the engine failure display on and it affecting the gear changing,
every time the gear change the engine will rev higher unill it complete the gear change. the is like in manual car, when you change the gear manually but you forgot to lift off your foot from the accelerator so the engine rev.
this also causing the computer not to change the gear at the correct time.
send to fiat to diagnos but they not sure why, so they just reprogram the ecu.
it cured for about 4 hours and it come back again.
