New to the forum and first off I apologise if this has been covered before! I have been and will be trawling the forum all night but with limited access to internet and limited time I'm going for the new thread.
Our 2006 1.1 Fiat panda has died a death in Mongolia and with a scarcity of Fiats this side of the world our option is an engine swap from a 2006 1.4 punto.
Can anyone confirm or deny that, these both being 8v fire engines, a straight swap is not only conceivable but should be fairly straightforward. As far as I can find, the gearbox will bolt on no bother. Size wise, the panda has a 1.4 variant which I presume uses the same engine as the punto and so engine mounting should be straightforward?
The boy has so far only agreed to part with the engine but is there anything else I really should try and scavenge from his car, (fuel pump?) he's selling reluctantly I think and so brakes etc are out the question, essentials to make the engine run only.
Is there anything else I'm likely to have missed or will need to consider?
As I said I will continue to search but any and all help would be much appreciated!!
Thank you all
Thank you all
