gerry norris
- Feb 11, 2017
- 58
- 22
Just about to do rear shocks When I read in mr Haynes fit new shock tighten bolts loosley fit road wheel lower to ground then tighten bolts how does one reach top bolt?? In all the years of running a garage never came across this. usually jack up on Beam axle remove road wheels jack under rear shock mount jack up release botom bolt slightly release jack remove bottom o shock from mount remove top bolt remove shock fit new shock let jacy down slightly to rough usual runing position tighten and Torque nuts as required never had any problems with this method before and no twisted bushe,s either
