Lamps by Post - For all your lighting needs
Thread Tools
Old 4 Weeks Ago   #1
100hp Timing Belt, Water Pump Kit
Car is going in for MOT and Annual Service in a couple weeks and looking to get the timing belt, tensioner and water pump done at same time.
Currently sitting at 67k on 07 reg, no record of it being done previously in the cars documentation/history although visual inspection of it appears fine. I'm a stickler for knowing things are done for peace of mind though and I know visual inspections don't always show problems with belts.
Can anyone tell me if this kit will do the job:
https://www.autodoc.co.uk/gates/7025857
It says compatible but I've noticed on EuroCarParts and on other sites too that there are two different impeller diameters on the water pumps, but both always say compatible - is it a big deal? If this is no good can anyone recommend the best kit to buy with a link?
Also - just to check is it a job any mechanic can do? I have a guy I use for general bits and bobs, he works for ATS but does the odd favour for me and is always very good with general stuff, but as timing belt is more difficult should I be seeking a fiat specialist or will they be able to manage it - I've read you need a special kit for timing alignment etc, would ATS have access to that?
Mrarteest is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
Re: 100hp Timing Belt, Water Pump Kit
its not particularly hard, but is quite fiddly. i asked a garage about doing my girlfriends and they wanted silly money, so just did it myself.
for another 15 you can get all genuine parts:
http://www.ebay.co.uk/itm/FIAT-500-P...sAAOSwewJTmxfq
dac69er is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Timing belts are time and miles sensitive so yours is well past its use by date.
Ive done a Mk2 Punto HGT. It's fiddly and you need some cam locking tools but its not an excessively hard job. Rebuilding a cylinder head is much worse. DAMHIK
DaveMcT is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
'08 100HP'
Gavv8's Avatar
Gavv8 has donated!
I'd get a garage to do it personally, one that did mine said the waterpump is a swine to remove and it's pretty tight in the engine bay.. pay a bit more and sleep easier.
Gavv8 is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Quote Originally Posted by Gavv8 View Post
changing the water pump is the easy bit.
if you take it to a garage, you always have to hope they do a good job, some do and some dont! i would personally rather do it myself and do it properly and know it is done properly.
Likes blu73 liked this post
Old 1 Week Ago   #6
Quote Originally Posted by Mrarteest View Post
Did you get an answer to this question?
I'm compiling my service items list for this weekend, and have came across the same findings.
DigDug is offline Reply With Quote Quote
Old 1 Week Ago   #7
Call Shop4parts. They know their stuff, don't sell rubbish and costs are reasonable.
Thread Tools
(T) What timing belt and water pump? puntohannah Punto (Mk2/2b) 9 17-02-2017 10:49
(G) Timing belt kit & water pump ozzy1993 Bravo 4 13-01-2014 16:57
(T) fiat ducato (2003) 15 swb 2.8jtd Timing Belt Kit with Water Pump davlins Ducato 2 13-05-2013 19:18
(T) How much for a timing belt and water pump? venturer Bravo 5 15-01-2012 16:27
(T) timing belt and water pump hiccup Doblo 2 04-11-2008 16:57
