Technical Dualogic reverse issue
Jonny3869
Hi. I have 2004 Panda dualogic. The problem is when it's at normal running temperature and you use reverse, it's jerking badly to the point you have little control whilst reversing. Any ideas as bow to rectify this? It has a new clutch fitted. It drives fine going forwards. Thanks in advance.
Was it recalibrated when clutch was done?
Reversing seems to show up out-of-calibration problems more than first does... kangaroo-ing shows up more at the lower revs used when reversing rather than going forwards.
The clutch wear index needs setting as well as a couple of other things.
If it was done it may need re-calibrating again anyway - it is quite easy to get it "nearly right" if not experienced, and the instructions I used were a scan of a photocopy of a bad translation. Which I now seem to have lost. I'll keep looking.
I think it could be a recalibration problem. If you find your information I'd be very grateful.
I believed MultiECUScan actually gives the steps for each calibration procedure.
I didn't have MES when I did it, it was a case of cobbling together old dealer kit and other junk.
It looks like the paid version of MES covers all of the steps I did plus some others.
Clutch drain/self calibration plus end-of-line calibration all have descriptions and procedure prerequisites which sound like a properly translated version of what I did, so that's probably the best way to go.
