Thread Tools
Old 2 Weeks Ago   #1
Panda 100hp rear suspension
Hi all never really used this site but thought I'd give it ago,
I have a panda 100hp and have got apex 30mm lowering springs rear normal bilsteins shocks and standard shock up front ( got bilsteins b6's on way from gazzella racing ) and when I put them on I had no problems what so ever but all of a sudden it developed a rattle.
I've takes the spings out repositioned them numerous times and I can't find this rattle at all, exhaust is fine, and the shocks are relatively new.
So was woundering if anyone has come across this or anything similar.
The rattle sounds like the spings are loose when going over bumps but they're not which is confusing me.
Thanks in advance
Jacque knowles is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
'08 100HP'
Gavv8's Avatar
Gavv8 has donated!
Re: Panda 100hp rear suspension
Quote Originally Posted by Jacque knowles View Post
Thanks in advance
Rattles from the back are usually either the shock top bolt or the rear seats.
Gavv8 is offline Reply With Quote Quote
Old 1 Week Ago   #3
Trader Rating: 1
petercresswell has donated!
petercresswell is an honorary friend of the forum :)
Suspension bump stops. I eventually fitted FEBI ones for a Bravo/a 182. 11 off ebay for a pair - 150 less than the short lived offering from the official parts bin. These also allow another inch of wheel movement which considerably helps the ride quality without upsetting the handling. I though there was a serious problem due to the large sounding noises but this was the cause. OE parts stopped the noises but only for about 15K. If you poke the old ones about they will probably break off and cannot be refitted. The 182 parts are all rubber and can be easily fitted by use of a bottle jack to push them into place once suitably lubricated with washing up liquid. You might want to try silcon mastic fist to take up the slack an d verify what i am saying by stopping these things moving about. Fixing this way won't last though.
petercresswell is offline Reply With Quote Quote
Thread Tools
(T) Panda 100HP cheapest fix for suspension? thesheep Panda 52 06-03-2015 15:15
(T) Best suspension arms for Panda 100hp swight Panda 3 28-10-2014 13:46
Poly bushes panda 100hp suspension prancing panda Tech Talk 0 23-04-2010 20:36
(T) 100hp uneven rear suspension brookes745 Panda 6 30-06-2008 01:14
(G) Putting Panda 100hp seats, alloys and suspension on 1.2 Panda possible? pietch Panda 14 07-09-2007 22:08
