milesb0801
- Jul 4, 2017
- 8
- 2
Hi all,
I have a 2004 panda at 70000 miles that I have had for just under a year now. In pretty tidy condition and have had no problems with it.
I have however now developed a slightly annoying problem. The knob on top of the gearstick has been loose for quite a while and if you were to change gear too enthusiastically it sometimes popped off, leaving you with a little metal pole which was sometimes a bit alarming! Bit it pushed back on fairly comfortably so I hadn't done anything about it.
I went away for a while and left a house sitter with use of my car for a month. She emailed me saying the knob had fallen off and she'd taped it back on, I presumed it was no big deal and was just what i'd experienced a few times. However upon getting back in the car something else seems to have happened.
The knob is now sitting on top of the plastic rim that is usually required to be pulled towards you to enter reverse. Meaning it comfortably shifts into reverse but you have to jiggle it around to find fifth gear which is a bit annoying and strange to suddenly happen... As you will be aware to enter reverse you need to pull the plastic rim upwards the knob, it basically seems to be stuck in this state.
As I say i'm not sure what happened, I could ask the woman who was looking after the house and car but I think she'd be pretty clueless. Is there something I can adjust? There is not a sufficient amount of the small metal rod sticking above the rim to allow me to push the knob back on properly now either - hence why she taped it on.
Anyone got any ideas? I suppose I could live with it and just glue the knob onto the top of the rim that you pull upwards, but it would be great if I could fix it and be able to shift smoothly into fifth again.
Might take some pics tomorrow. Thanks.
