Hi all
Any ideas what may be the cause of this?
Did my first longish run in the 100HP last weekend down to London from Norfolk. It was quite hot and humid and about 20mins into journey I heard this high pitched wittering noise coming from the front.
Initially I thought it was the front N/S brake squealing a bit, possibly due to heat/ expansion/ pad touching disc or something, but then realised that it only happened when the steering wheel was fractionally moved to the right from the central position, or when turning through that point.
So, not certain it was one of the brakes, but the noise was definitely coming from the front end.
Could it be a belt or something to do with the power steering?
Only recently bought the car and its under a 3 month warranty from the garage, who to be fair to them were pretty rigorous in carrying out necessary works to the vehicle before they'd let me pick it up. So, it makes sense to take it back into them to look at, but I just wondered if anybody else has experienced the same thing / has any clue as to what it might be?
Other than that, it was faultless and enjoyed the blast there and back. Averaged 47mpg, which I thought was pretty reasonable.
H
H
