My 1.2 Panda is exactly the same. I sorted it by putting some grease on the clutch pedal piston. Apparently it's common on Fiat/Alfas from what I've read/seen.
At end of life the Fiat clutch gets heavy to use and can feel like the something inside is bending. Eventually you either can't select gears or the pressure plate fails which I guess is the same thing.
