Thread Tools
Old 24-04-2017   #1
Ireland
Fuel pump dead. Gas cap or redex?
hello forum people.
I have owned a 04 panda 1.2 for 8 days now.
On the 5th day, the car started to lose power, couldnt rev over 2k rpm.
Then the car idled ok for a while and died.
I tried banging the fuel tank from under the car with my hands but with no results.
Called the tow truck man who highly suspected a bad fuel pump.
Confirmed later that evening. when I gently hammer the petrol tank, the car would start then dies after a few seconds.
Now my question is why did the pump fail?
a-on the second day I owned the car, I added some redex (inj. cleaner) to the fuel to give the system a bit of a cleanup.
b-The car's gas cap was stuck and could not be closed properly = no seal.
I bought a simple 99cent replacement gas cap and put it on the morning of the breakdown = fuel tank sealed.
When the car broke down, my first instinct was to check the gas cap. when I removed it, there was a loud swoooosh/suction noise
Could either cause a fuel pump to fail? Or am I just unlucky?
I ordered a fuel pump but am now wondering what could cause this and should i put that gas cap back on?
EricKob is offline Reply With Quote Quote
Old 24-04-2017   #2
Re: Fuel pump dead. Gas cap or redex?
unlucky
you could fit a new fuel pump fuse in case current one is cracked, yes its unlikely but it is easy and cheap.
jackwhoo is offline Reply With Quote Quote
Old 24-04-2017   #3
Ireland
i checked the fuse already
i m more worried/intrigued with that gas cap really
Old 24-04-2017   #4
If you have any doubt get a fuel cap designed for your model.
I cannot see the wrong cap causing failed fuel pump.
I have seen fuel tanks collapsed when then incorrect cap fitted but that was many years ago.
Old 24-04-2017   #5
It is far more likely your fuel tank is full of rubbish due to previous owner not having fuel cap.
Doesn't it rain frequently where you are?
Old 24-04-2017   #6
Ireland
it does rain quite a bit yes
I m only wondering about the fuel cap because with it on, 15 miles later, the fuel pump failed... i d say i ll drill a tiny hole in it just to be on the safe side?...
Old 24-04-2017   #7
water in tank could cause premature pump failure.
It is unusual for any modern vehicle to have a vented cap due to emission regulations.
If your current cap is what can be called an emergency cap its worth getting a correct one for safeties sake.
Have a look on mickscarparts its Irish.
Old 24-04-2017   #8
irc has donated!
I think a vented cap will cause EML to light up, as will not "clicking" the proper cap when fitting it.
Are you sure it was "sucking" and not "blowing" when you released the cap? (Stand by for some crude comments...)
I'm fairly sure there should be either be no pressure or a slight positive pressure when releasing the cap.
You may have a blockage.
Likes jackwhoo liked this post
irc
Panda Sporting MultiJet 1.3 "Diesel Weasel"
Panda Eleganza Dualogic 1.2 "Magic Panda"
Panda Active 1.1 "Moley"
Panda Active Eco 1.1
irc is offline Reply With Quote Quote
Old 24-04-2017   #9
Ireland
You re right. it was more of a blowing noise.
Are fuel tanks completely sealed (no air in, no air out) or do they have a venting mecanism, valve?
The cheap cap i got is just doing that job: sealing the 'hole'.
Ah, i think i m just overthinking this
Old 24-04-2017   #10
Honestly just buy a proper cap designed for the car.
There are a number of complicated emission control systems relating to the fuel system that can cause problems by the wrong or missing cap.
There is a system which allows air to enter the tank , so a vacuum is not formed on the tank which would collapse the tank under outside air pressure.
Just get a proper cap , honestly it's best all round.
If you don't get a proper cap now and later have problems you will kick yourself.
Likes EricKob liked this post
Old 24-04-2017   #11
Ireland
I ll take your advice
Thanks mate
Thanks jackwhoo thanked for this post
Old 24-04-2017   #12
No problem , thank you for listening.
Old 25-04-2017   #13
France
Sorry to hear about your troubles. I've got a fuel cap on a scrap Panda you can have. PM me your address and I'll get it sent from the UK early next week (in France at the mo).
Incidentally I've used Redex injector cleaner a few times and it's made a big difference to performance, so I wouldn't worry about that having damaged anything.
Chamonix is offline Reply With Quote Quote
Old 25-04-2017   #14
Will run fine without a cap for testing
Shouldn't have much vacuum when releasing the cap
There can be positive pressure and release of air when undoing the cap.
Can you hear the lift pump whirring when you switch the ignition on
Have you got fuel in the car. Having just bought it don't rely on the gauge.
If the pump in the tank isn't switching on there was a common problem with the ECU pins corroding.
I the car has been standing before being sold there may be water in the air filter. Also a very common fault.
http://www.fiatforum.com/panda/15296...old-start.html
koalar is offline Reply With Quote Quote
Old 25-04-2017   #15
Used pumps are not silly money
http://www.ebay.co.uk/itm/FIAT-PANDA...IAAOSwfVpYrAgM
Yo can also but a new motor/pump unit for about 30. Basically all the same
http://www.ebay.co.uk/sch/i.html?_od...+tank&_sacat=0
I recently fitted one to the bike & works perfectly. Has to be better than 200 that BMW want for the whole tank mount and frame etc etc.
DaveMcT is offline Reply With Quote Quote
Thread Tools
(T) 86 X1/9 Gas Cap Problems shawninohio X1/9 10 19-02-2014 01:02
(T) Fuel pump dead... Or?! Bobblo Doblo 1 06-10-2013 21:17
(T) Could this be a dead fuel pump ???? driverhgv Bravo / Brava 9 07-01-2007 14:06
fuel pump and gas tank lid questions!! Miroslav FIAT Boo Archives 0 26-08-2002 02:19
