500 axle update
It's now been though the winter and Ive had enough of the low riding back ends put the 169 springs back under the car. Its a quick job.
Loosen rear wheel nuts.
Chock front wheels and jack up the back end until the wheels are 3" off the floor.
Support the car on axle stands under the rear sill jacking points. Unless you have special slotted axle stands, use a 150mm length of 25 x 50 wood under the axle stands to protect the sills.
Remove the rear wheels.
Trolley jack under the centre of the rear beam does the lifting duties.
Put the jack under a spring pan and remove the shock absorber bottom bolt. They are long and fine threaded so a battery power drill is great for winding them out. Don't forget to et the torque limiting ratchet.
Move the jack and do the other side and remove it's bolt. Adjust the jack so the drill isn't labouring. They are long bolts so can bind. I had treated mine with anti seize paste, so they came out nicely.
The axle will now drop down allowing the springs to come out.
Swap the springs. To protect the paint, I put spring top rubbers at both ends. Those who want to lower the car can so so at low cost with 500 rear springs. The rubbers on both ends give it a slight lift if you don't want it too radical.
Put the jack under a spring pan and lift it enough to get the shock absorber bolt back in. You need to do each side separately because jacking the axle mid-line list the car before the bolt can fit.
Repeat on the opposite side. The power drill will wind the bolts in quickly.
While under there give the whole lot a good clean and spray with Waxoyl.
Refit the wheels and drop the car off it's axle stands.
Today away your stuff and - Job done.
