I'm having an issue with my car and it's running really rough. OBD scanner gives me codes p0105 and p0110 as faulty codes. I've changed my MAP sensor and it didn't make any difference. My car is a Fiat Panda 169 2005.
Now I believe that the MAF sensor is what's causing the MAP to fail if I'm not wrong. But where is the MAF sensor located?
I've looked around the intake hoses and the only sensors along it are connected to the throttle body. One is the TPS sensor and other is MAF I think? I checked the voltage on it, it had two 11.55v connections and two ground. If that's the MAF sensor, how do I test it with a multimeter?
