So I recently changed my MAP sensor when the old one was going bad, or so I thought. The new one (aftermarket from ebay) is behaving the same way.
The car throws out white and black smoke when the sensor is on, without it's normal. The spark plugs were pitch black, changed these. O2 sensor is new. Consumes 19l/100km when sensor is on, so it hasn't been on for a while now. Went normal after 30 minutes of sensor change, next day issues came back. Hesitates strongly during acceleration and then suddendly accelerates, you can hear it throw fuel into the engine when you accelerate with sensor on. Very hard to accelerate during stops on low gear, could suddendly stop accelerating. Loud exhaust sound when that happens, could be because I have a hole in the muffler. Tested sensor with multimeter, no change in voltage when you accelerate, both old and new sensor behave the same way.
You're probably wondering why I'm not taking it to a mechanic, well firstly it could cost have a lot and I can't afford it yet. Secondly I like the challenge. But it's becoming very tiring now when the issue remains after so many attempts to fix it.
Throttle body is changed as well.
Anyone who had a similiar issue?
Thanks in advance.
Thanks in advance.
