Lamps by Post - For all your lighting needs
Thread Tools
Old 14-03-2017   #1
What did I do wrong?
I joined this forum because of my interest in a Panda and hoped that someone could help me with a technical problem I am very disappointed with the response I have had so far. See my post "Panda confusing electrics" Is there anyone out there who has a wiring diagram for a Panda 2004. What is, where is the short circuit coupling? I now I have a OBDMATE but that will not communicate with body-computer control unit. Help! what do I do Next?
Our kid is offline Reply With Quote Quote
Old 14-03-2017   #2
irc has donated!
Re: What did I do wrong?
Quote Originally Posted by Our kid View Post
I think your original post may be in the wrong forum (Panda 2012+) which could explain the limited responses.
As I understand it your Panda does not start, and has no electrics apart from Hazard lights and some others.
I have a few questions...
What model/engine Panda?
Do you have sidelights or headlights?
Definitely no dash lights?
Do you have radio or 12v socket feed when ignition switch is on?
I don't have many suggestions yet, the only time I have seen something similar was a total failure of the Body Control Unit (BCU), caused by physical damage. It wasn't my car, but I vaguely remember some functions working but most not.
Thinking along these lines, try disconnecting the battery for an hour, then reconnecting. If no difference try another battery if possible.
Get some proper contact cleaner if you don't already have any, and (with battery disconnected) unplug and clean the contacts for the ECU and BCU. Re-plug once dry, reconnect battery and try again.
Post the results and hopefully someone will have a better idea of what is going on.
MultiECUScan and an ODB cable would probably be able to tell you if the ECU has lost communication with the BCU. Maybe there is a FF Member locally who can assist.
irc
Panda Sporting MultiJet 1.3 "Diesel Weasel"
Panda Eleganza Dualogic 1.2 "Magic Panda"
Panda Active 1.1 "Moley"
Panda Active Eco 1.1
irc is offline Reply With Quote Quote
Old 14-03-2017   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Will the OBDMATE connect to the engine control unit? If so it is probably OK. Unfortunatly the simple generic readers will not connect properly to additional modules like the BCU. There is a good program called Multiecuscan thet is Fiat specific and a lot more useful.
Exactly what model, year and engine is your car? We can then give a bit more advice.
Are you getting any warning lights on the dash?
I know you have checked the earths, but try connecting a jump lead between the battery negative and the engine block. Where are you located?
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 15-03-2017   #4
Panda Active 1.1cc petrol, I have sidelights and warning lights etc but these are supplied in the MAR position. Definitely no dash lights.. Radio when off when lost electrics. Haven't tried fag lighter yet. Tried contact cleaner trick. Fairly sure about earths I have 12.21vs from battery red lead to engine camcover. Brand new Obdmate OM123 but will not communicate with BCU. Fairly sure ignition switch Ok But in my desperation I am thinking of shorting it out. Still don't know what the short circuit coupling is or where it is. Not sure what the button under the passenger seat was supposed to do but pressed it several times. Don't know if keys are coded anyone know? Will try the disconnection of the battery tomorrow. But can't believe it is that simple.
Thanks multipete, Moimo thanked for this post
Old 15-03-2017   #5
Goudrons has donated!
So it's been sat of the drive for months, occasionally started up and you have 12.21 volts at the battery.
I've hazard a guess there's not enough in the battery to start it up.
Even though it's a 12 volt system, batteries usually charge at around 14.5 volts.
Also, volts are only half of the equation, you need a lot of amps to start an engine.
Modern cars don't tend to attempt to activate the starter motor if the battery isn't in good nic, so they don't tend to give you that slow whur, whur, whur crank of car's years ago.
You normally just get a lot of relays clicking and perhaps the clock needles jumping about.
Charge up or swap the battery out with a known good one.
If the battery is really pancaked flat, they don't often take a jump from another car.
The button under the seat is the fuel pump cut out reset button, I think.
In the case of a bump or accident, the system detects this and cuts the power to the fuel pump.
This button resets it.
Goudrons is offline Reply With Quote Quote
Old 15-03-2017   #6
varesecrazy has donated!
Which of your threads do you wish replies to be placed in?
Old 15-03-2017   #7
Put the headlights on even though they don't turn on. Then measure the voltage.
koalar is offline Reply With Quote Quote
Old 15-03-2017   #8
I'll reply on this one if you don't mind. Thanks Goudrons but even a battery with very low voltage should bring up dash lights. I have disconnected the battery and done a bit of shopping and reconnected but no dice. I live in Morecambe incidentally and I am no novice on cars/motorcycles, diesel engines and even on steam engines/turbines etc but computer stuff I am not so hot. This problem has been a headache for the moment. So here is my thinking, it could this elusive short circuit coupling, It could be the ignition switch or key code, it could be the CBU or engine control system, but I suspect it is something simple that I haven't latched on to. I am hampered by a Hayes Manuel wiring diagram which is not the one for this particular model, a workshop manual I can read and is next to useless, and the handbook that does not show the fuse pattern that fitted on this car. Oh! and very time at the moment.
Old 16-03-2017   #9
Dean
Zeewulf's Avatar
Zeewulf has donated!
Have you downloaded eLEARN from this site which should give you a bit more help in trying to problem solve this. Plus Fiats really don't like low battery states and usually throw up all sorts of errors. Even if you think it should be ok it's worth giving the battery a full charge before proceeding further, at worst it's just a day while it charges, at best it does cure some strange faults that show up from time to time.
http://www.fiatforum.com/downloads.p...downloadid=485
Blue & Me Website - http://www.blueandme.net/blueandme/index.aspx/
Zeewulf is offline Reply With Quote Quote
Old 16-03-2017   #10
irc has donated!
The immobiliser shows a dash light when ignition is switched on. It should then go out as the code is accepted.
As I understand it, yours is not doing this. So I think the BCU is not trying to read the code.
Did you make any changes to the car between last successful start and first failure? Even something which should be irrelevant, like hoovering it out or checking the oil?
I'm also hopeful that it's something simple, like a dislodged connector, but I'm struggling to see a common denominator apart from the BCU at the moment.
irc
Old 16-03-2017   #11
Have you tested the battery voltage with the ignition and head lights on. As per post above.
There is quite a load when you first switch the ignition on. Fuel pump and two computers kick in.
Surprise If anyone knows what happens as when the battery gets old the power steering starts to fail first.
As an example when the battery is very low on a Corse B the dash doesn't light and the hazards come on. The only way to stop the hazards is to disconnect the battery.
Old 17-03-2017   #12
Short Circuit coupling........ otherwise know as a fuse!
Have you checked all the fuses including the larger ignition fuses under the bonnet and in the interior fuse box.
If you have access I would still put another battery on it just to rule that out or take your battery off and put it on a long charge.
Once you've established some basics then I'd make sure that there is power to the fuses and see if the ignition is powering up the systems properly, any low voltages or absence of voltage could point to a knackered ignition switch.
There are other possibilities but start methodically and work through the basics
For all my Punto and Punto Grande Instructional Videos Visit My YouTube page
MyNew Website is now at www.puntohowto.com
Or check out the Facebook Punto page
AndyRKett is offline Reply With Quote Quote
Old 20-03-2017   #13
Thanks for your help lads I will try and answer your questions as I come to them. I gave an hour of my precious time today on the problem. Fitted a good fully charge battery. No go. Just the same. Seewulf I got a CD via the internet can't remember exactly where from. My computer security would'nt let me open it. Asked my friend to download it to my computer and we looked at it but no wiring diagram that was relevant. My security system won't let me access it. Didn't find it much use anyway. Irc, No lights on dash at all flashing or otherwise only clock. No fiddling at all, one day started, next day didn't. Koalar, Battery voltage with ignition and headlights on. Nothing. AndyRkett Short circuit coupling known as fuse, is not true, conventional electrics drawings show the ultimate safety device and when the fuses are blown as a short circuit coupling or circuit breaker. The Hayes Manual shows such a device and my car is wired as the starting/charging system in it. The only thing I can believe in at the present. More later.
Old 20-03-2017   #14
Moderator
g8rpi's Avatar
g8rpi has donated!
Your "Short Circuit Coupling" could be a srash switch isolator. Thei is like a fuse but is electrically operated (some use a small explosive charge) normally by the srash inertia switch. These are normally mounted on the battery. If you are getting power to the ignition switch it's probably not gone.
I suggest you pull the body computer out and have a good look at it including connectors and any plug-in relays or fuses.
Robert G8RPI.
Old 21-03-2017   #15
So what did I do today? As I say I fitted a good battery and retried what I have done before. First tried the OBDmate again, still will not communicate This is because there is no power on the socket I'm fairly sure. There is power on the red lead to the in car fuse box. Check ignition switch several times. Power on the red lead going into it OK. I get a flick (but no power) on the orange lead which changes to light /blue lead which supplies fuse F16 which of course may not be the same in my car. Nothing at all on the brown lead which is to the starter motor but no juice. Fuse 16 ??? runs from fuse in light/blue and red to supply short circuit coupling which in this case I assume to be the under seat switch. Power assuming it is working runs from the this to the engine management control unit in orange/white. So I think my problem is in the ignition switch (likely) the short circuit coupling although it did click when I first tried it or the EMCU. That is where I will try first. Find wire light/blue and red test that. Find wire orange/white and if that is not it I've got to get power to the body control unit. This is of course that my car is wired as this diagram. I'll keep you posted.
Thread Tools
Punto (Mk2/2b) Ok, so what's wrong with it? Eklipze3k Auction Watch 5 08-07-2011 11:25
(T) Wrong strut brace or does my car have wrong suspensin mounts? Momanatorz Punto (Mk2/2b) 7 21-01-2010 20:46
(G) Something is wrong? AY786 Punto (Mk2/2b) 4 24-04-2008 15:33
(G) What wrong now!? RazmaGT Punto (Mk2/2b) 1 26-03-2008 15:04
(G) I didn't buy the wrong car I just live in the wrong place allanhelen Grande Punto 7 03-06-2007 18:08
