- Sep 14, 2009
- 19,492
- 3,294
The latest Yamaha 900 triples have a cross plane crank (two up, one down) presumably they also have a balance shaft as they are very smooth.
Any modern car showing 6 volts will play up. You might was well connect it to an EverReady torch battery.
Fit a decent battery, Hot wiring across the old one wont help as its almost certainly short circuit internally.
Drain the manky old petrol. Stale petrol often wont start.
Ring back when you tried that lot.
