Pandasaurus
- Mar 12, 2017
- 14
- 3
I had intermittent problems with my Panda (54 plate). It ran fine and then would not rev past 2.5k. I researched a number of threads and jumped straight to the fuel pump, that i replaced. Now it won't start. Prior to this, The code reader would not provide any error codes at all, when I turn the engine on, the new fuel pump primes and does have pressure ( I removed the hose like a retard) safe to say no one will be smoking in the car for a while. I have checked all of the fuses under the bonnet. They are fine.
I have removed the HT leads from the ignition coils. they seem fine. I can't remove the h T leads from where they are attached to the spark plugs - they are seriously stiff. I really need tome tips on prising them off as I am unable to do this. (I rock climb and have a pretty firm grip) as I really wanted to check if there was any form of corrosion on them.
Could the Panda have been immobilised when I disconnected the battery to replace the fuel pump? If so, what tricks are there to make it run again? How do I check if the crank has slipped a couple of teeth? And how do you remove the HT lead form the spark plug with shredding them?
Cheers.
Cheers.
