Hi All,
Have just bought a 2009 1.3 MJ Dynamic and am still getting used to it and cannot vouch for the battery's quality.
Yesterday I fitted a new Kenwood aftermarket stereo using the generic Autoleads ISO DIN adapter. Radio turned on / off with ignition - kept its programming after ignition off - thought I had cracked it.
This morning, battery was totally flat - even the clock was dead :-(. I recharged it with a mains charger and went to have a look at the forums. I saw the warning that draining of battery by new HUs is a known problem, so pulled the connections. Checked the fiat's radio socket with a multimeter and I'm getting a good earth and 12v constant feed and my car's loom is also providing an ignition switched 12V.
However, according to the wiring diagram, the panda shouldn't be providing a switched 12v pin and I notice that it is not 'clean' when off as its measuring 0.2v. I pulled the new radio out whilst looking into this and went for an engine start.
Turned over beautifully and started immediately, but noticed the Engine warning light is on constantly :-( . No problem with performance, tried a few restarts but it keeps glowing constantly.
So, may I ask:
1. Do you have any thoughts on the radio drain problem and
2. Any thoughts on the constant engine warning light?
3. From looking at the forum - poor battery quality and engine lights seem to be linked - could that be it?
4. I saw a post about start / stopping engine 4 times in quick succession to reset warning light - is that correct or is there a better way to reset it?
5. Finally may I have screwed the system by turning the ignition to MAR to chech the radio voltages whilst it was on charge at 14-15V?
Any ideas / advice gratefully accepted - many thanks in advance
Malc
So, may I ask:
Malc
