- Jul 20, 2016
- 210
- 51
So last summer I did a motor swap on my 1,2 2010 ciao, it had a bad oil-pump, which made the clearances go all over the place, so she got a new 1,2 188A4000 which had done around 35.000km at the time, I've done around 10-15kkm on top of that in the last year, we almost never run it hard, meaning 3000rpm is our normal limit, some very rare times its been to 4000rpm, and once I've had it to 5000.
I noticed the white smoke the other morning (the wife pulled out of the driveway), didnt think much of it as it was a frosty morning. but doing a springcleaning today it had coolant midway between min and max while being topped up not a month ago, and the oil is ever so slightly mayo-ish - I do have a test set, but I doubt its necessary as the symptoms are there - but I will of course check before changing the gasket.
But my question is, what did I do wrong? swapping the gasket, will that just cure the symptoms, and it will reoccur shortly afterwards? I've not overheated - what can cause this?
Also it's not running badly in any way, starts right up, and sounds right.
And will any further harm come to the motorblock from me postponing the gasket swap a month or two?
Thanks for reading,
Tobias
Thanks for reading,
Tobias
