Sure I read ABS is a big issue if you run the car with no brake fluid in
Other than that point it's just like it's not there for the cylinders.
If you have one leaky cylinder the other probabley won't be much better (done both mine 48K ago)
But as you probabley know if it's leaked it will have leaked inside the trum and will certainley have contaminated the shoe, so new shoes too.
I had a right pile of parts when I did... cylinders, drums, shoes, auto adjusters, fitting kit and new cables.
one drum got knackered when the lining fell off the old shoes (Bosch ones they were)
Both auto adjusters were knackered and was the most expensive part (£200 for all the above)
Like Trimdoner one brake pipe nut would not turn, so I spun the cylinder and held the pipe still. Not sure if it was the one that had a snapped belld screw before I started.
