- Jul 20, 2016
- 210
- 51
So finally got time to lift her, and crawl under her to swap the U-joint, and have a look, first thing I noticed when I got the cover off, the U-joint is spot-welded on, meaning it can turn frely, but it cannot be taken out without applying heat (and likely melting the joint).
getting the screws marked "B" unscrewed I realised the driveshaft had loosened, and can move somewhat around in the cup? marked A, I aligned it again, but I dont believe this will hold for many minutes, so it might actually be whats causing the shake/noise, as far as I can discern, it cannot get out of the cup while under tension from the middle part. C, the sock? moves back and forth under light touch, I have no idea how it's supposed to behave.. I guess I'll have to order a new propshaft? since this is "slightly off balance"...
the spot, D in the third picture is after the Viscous Coupling, is where it moves back and forth in the differential, I was under the impression that the viscous coupling should allow small movements to happen to one end without transferring it, but this seems like its not the case?
