Bleed screw has a slot along its thread, so soon after it is turned coolant will trickle out. No need to remove, in fact best not to. Let it trickle gently until only coolant comes out. tweak it closed with fingers only, no tools, or it will be too tight and seize shut. Opening it too far may well cause the escaping coolant to draw air and create bubbles.
