newbie fiat
- Aug 4, 2016
- 96
- 27
im about to change the coolant as its coming up to winter and the previous owner only had it done once in 10 years, i have been looking at. 523770482 on euro car parts site
is this suitable? it is red antifreeze / coolant but i cant see a reference to OAT anywhere, has anyone used this before?
also just to confirm (if someone has more detailed info, preferably pictures as i don't know what the bleed nipples look like then please let me know), the process is undo the hose clip at the bottom of the rad, open expansion bottle to help with flow and the 2 bleed nippes (more info on this please) re-connect the hose, top up with water and close nipples. run engine till upto operating temperature with heater on full. drain system again. add a 50/50 mix of antifreeze and water unless i buy pre-diluted and fill (does anyone know the capacity? it doesnt say in the handbook...) upto the max mark then open the nipples to let any trapped air out, (can someone confirm which nipple to open when?) top system back up to full. close cap on expansion bottle, run engine till temperature is reached again with heater on full. check level and top up as necessary. run for a few days and open nipples again to let any final bits of trapped air out.
apologies for the messy post its all coming straight from memory of other guides i have read.
(technical level: beginner going on intermediate, i have fully stripped, cleaned and rebuilt a motorbike including the engine carb gearbox etc and maintained it for 2 years, but i am a novice with cars. i have done the rocker cover seal and an oil and filter change since i got my little panda 2 months ago)
cheers
cheers
