I've fitted a new regulator (as per previous post drivers windows was help up with a piece of wood)
Now : when i open and close the passenger window you can hear the RELAY under the steering wheel click and the window goes up and down as it should.
However : when i press the drivers window switch NOTHING no click Ive checked the fusses and 47/48 are both sound (20amp).
Does each window have its own relay ?
I've looked under the dash after removing the dash fuse board cover but cannot see any relays..
Does any one have a photo of the relays ?
I'll pick up a multi-meter to check the wiring hopefully tomorrow.
Any other suggestions ?
thanks....
thanks....
