Technical Exhaust replacement
I saw tools available but did not buy any, and didn't need them.
I used a tool I have for internal carpentry, which came with a metal cutter, to cut off the silencer, see:
Bosch PMF 190 E Multifunction Tool with Cutting Discs, Saw Blades and Sander Sheets: Amazon.co.uk: DIY & Tools
I thought it would be easier to cut it off than separate the joint. It was not difficult to cut, though given the access I'm not sure I would want to cut with a hacksaw.
Wrench and socket to open clips, hammer and coal chisel to separate the joint at the CAT, multi-tool to cut exhaust, knife to cut rubber hangers (make sure you have replacements before doing this). The rest was heavy duty gloves, mask and eyewear.
The kit I purchased came with everything (including replacement clips, cement, and rubber hangers).
