- Jun 3, 2016
- 149
- 56
Hi, '05 1.2 petrol 4x4, parked car up at night, no issues but would not start next morning. Turning over with good battery but refuses to fire/start. Code reader shows no faults, timing belt OK, plenty fuel, no other warning lights etc showing. What should be my first port of call?
Had exactly same problem, But the codes pointed to the crankshaft sensor.
DONT use a cheap replacement! there is no marking on it to identify it!,, I had one which worked for 1 day then back to non starting. The 'original' part was put in and she starts up first time every time.
One way to check is to remove the sensor (the AA did this for me 3 times in 3 days!) and she started but then next morning the same thing which once the sensor had been removed and replaced she started again. I was told at the time that the wiring may have corroded causing this problem but as ive said, once the new original part was installed ive had no problems and no more sleepless nights worrying if she'll start in the morning. Hope this helps?
