Does it have ABS?
As ABS was mandatory from mid 2004, only the earliest should be non-ABS. As said above, if it has ABS, any skidding should be addressed by the ABS system.
Does the ABS warning light come on with the ignition and then extinguish after 3-4 seconds? If the warning bulb has failed, you won't know the system has shut down.
Having said that, at most normal speeds and braking, the ABS should not be necessary as skidding should not occur. So first carry out the physical brake checks as above.
