- Sep 14, 2009
- 19,492
- 3,294
Stainless is easily available on eBay but DON'T USE STAINLESS bolts/screws.
Zinc plating works because it has a higher anodic index at -1.25V so the zinc erodes before the steel.
From Wikipedia
(1) Its barely as strong as basic 8.8 material.
(2) It has very little spring so threads go suddenly tight and can shake loose all too easily.
(2) It WILL to cause electrolytic corrosion of the plain steel threads. See below
From Wikipedia
Stainless steel Anodic index -0.5V
Iron and low carbon steel -0.85V
Difference of 0.35V is more than 2x acceptable for the harsh environment under a car body.
Harsh environments, such as outdoors, high humidity, and salt environments, there should be not more than 0.15 V difference in the anodic index.
