We discovered on Friday a little dangling item under the Panda.. Much less strange than it sounds I assure you..
Apparently welding that back around the exhaust is an easy enough task and should work well.. Or is there anything important I should know that I'm overlooking?
This could be responsible for a grinding like noise happening when the car is accelerating hard under load.. Thoughts?
