Hi all,
Strange goings on with our 2004 Panda 1.2 Dynamic
Car intermittently fails to start. Engine turns over but no attempt to start.
Sometimes the dash goes off whilst the starter is turning over.
Battery is good, starter works well, and have tried a second fully charged battery with same results.
Then when the car starts it sometimes does the following;
1> If you select reverse the dash goes off completely including dash warning lights, clocks & rev counter and the engine switches off. This is whilst the clutch is still pressed in - so not stalling when pulling away. When this happens it's just like the battery has been disconnected - the dash goes completely off. Alternatively putting into reverse will flash the majority of the left side warning lights before cutting the engine.
2> When driving the POWER STEERING FAILURE DASHBOARD WARNING LIGHT will flicker or stay on on the dash although the power steering continues to work fine.
3> When driving the CAR PROTECTION SYSTEM FAULT WARNING LIGHT will illuminate and stay on on the dash. Car continues to drive ok when this comes on.
4> When driving the car and using the brake pedal it will sometimes flash all the lights on the left side of the dash before cutting out the engine. This has happened when the engine is cold.
5> The AIRBAG OR PRETENSIONERS SYSTEM FAULT WARNING LIGHT has flickered sometimes, but not at all often.
I'm wondering if it's something to do with the ignition switch - if you wiggle it when the car is running it will sometimes switch the car off. Just like the reverse problem it's as if someone has pulled the battery - the dash goes totally off. But, this only sometimes, other times when it's running wiggling the key makes no difference. Also when trying to start it if it wont start wiggling the key whilst it is turning over does not help.
We've a spare key, one without the remote fob and that works just the same.
If all is well the car runs just as it should, no problems at all.
Thanks.
Thanks.
