i wanted to fit a power socket to the Panda i got for my daughter so she could charge up her phone / ipod etc. it doesnt have a socket fitted
it has power leads fitted in situ under the handbrake cover but they have no power at all going to them so i assume they are not connected up - the loom is generic.
i decided to cut into radio power lead as it was easiest to access. as soon as i did it lost all power, radio would not work, and when ignition turned on the speedo flutters then settles and the clock and odometer flash but wont reset.
if i run power straight to the radio from battery the radio works but clock still flashes
checked all fuses but none blown ????
