Good evening guys,
I've noticed something about the brakes which has alarmed me slightly. Under heavy braking (not light braking) there is a vibration noticeable through the brake pedal. I can brake fully with no problem (so not brake fade as such) and additional brake effort isn't needed, but it's the vibration which is alarming.
I could use a DTi gauge if I had one to check the rotors for run out. The front brake discs don't have any noticeable (to the eye) grooves/ridges or heavy rusting.
I'm wondering if it could be just a build up of brake dust and would it be worth stripping and giving everything a clean with brake dust cleaner?
P.S - I had a service in January and the brake pads and rotors were completely fine. The front pads were 9mm thick.
Matt.
Matt.
