Hi there, looking for a bit of help.....brought a 1.1 panda 3 months ago ,had issues with bad misfire (running on 2 cylinders )..Had ecu tested all ok ,.replaced both coil packs and leads...started to run fine then had a small blip which put engine light on...checked this & was map related ...took out map sensor and cleaned , all ok apart from I now get a few hiccups & engine light flashes on then off....seems to be mostly when I go over speed humps when i decelerate but always at low speed. ...Car runs fine when driving about at higher speeds....thinking maybe a loose connection ? Any ideas would be really appreciated. ...cheers Dean...
