Technical No power to fuel pump
Zubair
Cape Town
Hi guys
I've had a huge issue as i tried to start my panda 1.2 and the pump didn't work, i tested the pump an its fine, i ran a direct line to an ignition+ to check but now the pump goes on with my mechanism but no fuel gets to the throttle body to start and the pump pushing as normal, please help had this issue for months now with the car, please what else can i check as well as my fuse cover does not say what relays or switches can be an issue
Hi guys
without going through your previous posts..,
the main reasons for the pump not running;
FIRE prevention cut-off switch - under seat
Immobilised - symbol on Dashboard
electrical supply - power OR earth
:idea: IF it's "locking- out" the fuel supply , you by-passing the pumps power MAY mean that the next part of the fuel system is NOT enabled either
I've never seen mention of a fuel pump power supply fault on a panda.??:confused:
Charlie
Thanks a million guys, I think it might be the crank sensor as everything else should be fine i hope it is though...
lol hahaha that was the sound yes but i thought it came from the under the hood, anyways guys thanks alot, i managed to run a wire from the pump to the ignition live and so far its going good, still wanna find the problem though
