jonah100hp
- Dec 4, 2013
- 14
- 5
I have just fitted a Magneti Marelli straight through exhaust centre section with my standard back box and although I like it and its an improvement its still not quite the noise im after.
the note I have at the moment is quite deep and boomy and I was hoping for somthing a bit higher n raspy.
The clips I have seen on you tube with my current set up suggest that what I have should sound more like this. I think the problem may be that my back box although standard spec is not genuine Fiat but after market and and even with the standard centre section was always a bit deeper than original.
So the decision I have to make is whether or not to get the Magneti Marelli back box as well with the twin pipes. Watching videos on you tube with the centre pipe and back box suggest the sound created is exactly what I want (high n raspy) However it does sound VERY LOUD! What I need to know is has anyone any experience with this set up? and is it as loud as the vids suggest? I do not mind a loud exhaust but there is a limit.
