Just sat and typed this out but lost it
Anyway, tried to replace my antifreeze. Couldn't get the lower radiator hose off. As far as I'm aware this is the only way to drain the coolant.
Tried to loosen the clip, loosened it. Would. Not. Budge.
Ended up with pliers and ended up pulling the clip out more than it should be / ruining it from inside the ankle joint.
Think I need to buy a new ankle joint to be safe as this one I'm worried will blow under pressure or come loose over time. And even if I did get it off, think I've ruined the metal clip inside the plastic ankle joint :-(
So I still need to get my coolant changed, have the big 5L bottle there of it, and am seriously considering taking it to my local Fiat Donelly & Taggart garage.. :-(
Attached some photos to show the clip and part I'm referring to, you might also see how I've damaged it.
Might get a new whole hose / clip / joint assembly on eBay and get a mechanic to fit it even?
Scared to move my car now :-(
Please tell me your recommendations and what I should do / similar experiences you've had?
Non air conditioning 1.2 petrol Panda 2005.
