Hi guys,
This evening, I drove from Manchester to Liverpool and I stopped half way at the services, however the second part of the journey resulting in a strange thing occurring.
The interior dash cluster; left indicator failed to flash, however the 'left' exterior lights flashed normally accompanied with the 'ticking', but the actual dash clock did not indicate. However, the right indicator illuminated perfectly. I put the hazard lights on to see if it would correct, however only the right indicator on the cluster illuminated. But, all the exterior bulbs lit, both left and right.
Anyhow, I turned the car off.. started it up again and the 'left' cluster began to illuminate when I put the left indicator on. My partner said the system 'being computer controlled' just needed resetting, but I don't know.
Obviously, it's working again, so I'm not too concerned, but will this become a common thing now, maybe with other dash lights? Does it happen/or has it happened to your car??
Matt.
Matt.
