General wheels
General wheels
triballofts
hi what are the biggest tyres i can fit on standard panda 13" alloy wheels also what are the biggest wheels that will fit a 2006 panda
would 175x70x13 fit the standard alloy wheels if so would they give better road holding being wider
I have 13 inch alloys on my Panda but I have the standard 155 80 R13s on them and don't have a problem. Can I ask what tyres you are using? I found that the standard Continentals weren't that great and I changed to Michelin Energy. I find that they're much better for holding the road. With tyres, I find that you get what you pay for. If you go for cheap tyres, they don't hold the road as good and they'll wear quickly.
The problem with changing from the standard size is that would change the rolling radius so that your speedo would be wrong. Unless you know the effect of the change in rolling radius, you might find yourself with a speeding ticket if you haven't adjusted to a corrected reading on the speedo.
hi thanks for that not sure what make are on at the moment they were on it when i bought it they are 155x80x13s though do you have a link to the calculator
I had 7x16" ET31 Black steel Bravo wheels fitted with 195/45R16" tires on my lowered ex-169 without any rubbing of any kind. ;)
i bet that cornered well bye the way what does os mean
thanks but still dont know what offset is what are standard panda 13" alloy wheels
thanks might give the 14" punto steel wheels ago when i can find a set
