triballofts
- Feb 26, 2015
- 145
- 46
anyone recommend a code reader please thanks
so better off using garage then really if the cheapos only turn off engine light
just thought it would be handy to read any other codes so you could check if everything was ok also handy when buying another car
so cheapo s no good for pulling codes and changing parts
Mine was a £10 one off ebay - generic for any car. I wanted it to reset the code as I kinda knew the car was a lying dog anyway. It will tell you all the generic codes.
Agree with that.
But don't buy Multiecuscan if that's your aim - or iCarsoft i950. They're dedicated to Fiats and Alfas.
You'll need a scanner that covers most cars - like a Foxwell NT600 or Autel 801. They cover the four main areas I mentioned above. Bit more expensive at £80 upwards, but worth it.
Your friends will love you too!
Can be done with multiecuscan.Also if you have a mJTD with a DPF you must use a Fiat specific setup to reset the oilchange counter in addition to just turning off the service light otherwise you will get DPF issues.
thanks everyone for your help
