I've had a look round but can't really see an answer, so hopefully someone will know a bit about the EML faults.
My 2007 Panda 1.2 4x4 threw the engine management light on without warning. It came on while trundling about at the zoo, and stayed on. No symptoms, engine running fine, no misfiring, no loss of "power", or increase in fuel consumption.
Local garage tried their generic tester as the Fiat dealer couldn't help this week(!), and it read "P0172 unknown fault". It then reset the light successfully and so far (only a day) it's stayed out. Does this code mean anything to anyone?
The battery had been flat after 2.5 months of standing, and the car had been idling oddly (revs rising and falling) starting from warm a few times. This had resolved itself before the EML came on though - connected?
The Panda has been throwing a flashing EML on motorway runs when it's working hard - this goes away again if you ease off. I'd put it down to the 113k on the clock & maybe a sooted up sensor or something (the handbook suggests a flashing light may be emissions related). A long motorway incline is most likely to trigger a flashing light.
Are these likely to be related, and is there anything likely to be causing it? I don't want to damage the car & it runs so well I don't think there's anything seriously amiss. It's a bit annoying (on its rare long trips) to have to keep backing off, when it clearly feels happy at higher speeds.
Any thoughts from the forum gurus would be welcomed.
