I have a 2011 1.2 69HP Panda which cuts out sometimes when accelerating in first from rest. As you can imagine this is a bit disconcerting, it is like hitting the rev limiter but at much lower revs (no idea what as no rev counter). The engine comes back to life if the accelerator is lifted or pressed down a bit. I have replaced the electronic throttle pedal, the throttle body and inlet air sensor. These items were all picked up on Ebay for very little off cars of a similar age to mine. I have also cleaned the contacts on the ECU. If you disconnect and reconnect the battery the problem goes away for a few days then comes back. I am sure the problem must be with the ECU which I know does have the latest software. As it is a late Panda the ECU needs to be matched to the car. Does anyone have any useful advise on how to change an ECU or anything else the problem could be?
Peter
Peter
