The panda passed its mot today,
but icame away with these :
Nearside Front coil spring corroded (2.4.C.1b)
Offside Front coil spring corroded (2.4.C.1b)
Nearside Rear coil spring corroded (2.4.C.1b)
Offside Rear coil spring corroded (2.4.C.1b)
Rear registration plate deteriorated but not likely to be misread (6.3.1d)
Tank straps corroded..
ive had a look at the Tank strap's and the springs, and theyre solid,
seem's the mot tester is Strict,
What do you rekon, Replace..or wire brush and coat them insomething,
anyone else had simalar Advisory's?
My punto had worse'r looking springs..and it wasnt mentioned.
as of rust its not rust as such, just a slight bit of coating coming off the springs in one spot.
