jonah100hp
- Dec 4, 2013
- 14
- 5
So I've finally decided to bite the bullet and I'm going to order a full set of Koni str's for my 100hp. I could do with just a little bit of advice; I believe that as mine is a 2010 model I will also need to change my front anti roll bar drop links. Where is the best place to source a suitable pair of these?
On the rear shock absorbers, what sort of tubing is it best to use to "pack out" the bolts to the correct diameter and where did you source it from?
Thanks for your help.
Rick.
Rick.
