- Sep 7, 2014
- 498
- 106
When braking hard from 80+ (on a private road of course) almost to a stop the rear feels like it wants to steer itself from left to right and doesn't give me confidence. It stops in a straight line though and it doesn't require steering input but I can feel the rear about to move out of shape.
When I had the rear pads changed around 5k miles ago, the pistons of the rear calipers were greased and pushed in, one might have been sticky IIRC.
The car passed its MOT fine though and no imbalance was reported on the brakes but maybe the sticky caliper is only marginal hence the problem appears at higher speeds?
I wonder whether this happens due to a worn front shock and the combination of the short wheelbase, has anyone else experienced this?
It happened with the OEM shocks and also after fitting Konis at the rear. I have yet to fit the front Konis.
I've used some Bendix rear pads, maybe these don't provide enough friction and the car feels imbalanced due to this?
Or is there a rear brake regulator that needs changing?
It's a 100HP.
It's a 100HP.
