642trigger
- Feb 18, 2015
- 10
- 1
the clock wont stop flashing help please pressed buttons nothing happening plus 12 hours behind
the clock is flashing permanently and you cant do anything with the buttons
was wandering if the button didn't work you could replace it??try disconnecting the engines battery for a short time( BLACK lead).. it may well reset,
do the buttons move freely..?? nothing "stuck..??"
Charlie
it seems as if the clock button isn't working properly mate also a beeping noise and the mileage reading disapears
thats how the car was when i bought itFrom the pics, it would appear that you've only told us half the story. Whilst the clock may be flashing, the top third of the display is not there! This displays the date, and when the OE radio is fitted, the radio station/frequency. Or have you photoshopped it for some reason?
Has this disappeared at the same time, or has this been missing for a while? It would appear that the display is dead, probably needing a new one.
If you need a new display, if sourcing a used one, you need one with a lower mileage than yours. Then using MES it can be updated to the correct mileage, but you cannot reduce the number.
