Question, is there a trick to opening the plugs that connect thr loom to the ECU, I don't want to break them open.
Hello mate,
i was happy reading all your progress regarding this issue with your car, once i have the same symptoms on my Corsa 1.3 CDTI.... but unfortunately you didn't came to conclusion.
main faulty code is also P0090, non start, when start, runs a couple of MTs or KMs, then stop and don't start again....
only changed the fuel pressure regulator, without any success. ( it run 60 KM after that but again same problem )
did you ever get to know what could be the problem? or anyone here?I really need help....
thanks.
