Just bought a 2007 Panda 100HP. Seems like a great little car – amazing for the money. As expected, the suspension is horrible. It is very bouncy and I occasionally hear+feel knocks from the rear end.
I'm planning to take it for a major service very soon and ask them to check over the suspension just in case anything needs attention. I'm wondering if there is an easy fix where I can tell the garage "just fit these third-party dampers" or whatever. I don't have much spare cash right now so whilst I'm looking for an improvement, I'm not trying to make it perfect or get the best kit available. Don't want to change the ride height. And I'm not really mechanically-minded enough myself to start messing around under the car myself.
I've spent a good while reading the 100HP suspension threads on this forum and from what I gather I could just order a pair of Koni rear dampers and those would help somewhat, and would not change the ride height.
Looking on a site called dcperformance.co.uk I've found a couple of Koni rear dampers: red STR.T rear dampers (Part Number: 8050-1106) for £42 each and yellow Koni Sport rear dampers (Part Number: 8040-1347SPORT) for £90 each. Looks like the Sport ones are adjustable but the STR.T ones aren't. I tried to post a link to the pages but this forum won't seem to let me post URLs so I've attached images of the products here.
Would it be effective to just buy a couple of the £42 STR.T dampers? And would the garage need to adjust anything else or would it be a simple swap over? Some of the threads I've seen on here talk about having to cut bump stops and modify bits of the existing suspension to get new shocks on, and I wanted to avoid that kind of thing if possible as I feel a bit out of my depth! I guess if the Sport ones would be significantly better I could stretch to those –*would they be easy to adjust after being fitted?
Any advice gratefully received
