Suggestion: Before you shell out heavily for this tiny valve, try unplugging, cleaning the electrical connectors with spray and reseating. Also check that the fuel filler cap seals correctly.
Might just save a few bob.
I just had that off to check the o rings!. It is definitely sealing, I tried to blow through it, but is it opening?, that is the question.
What a price!.
So it's possible the problem is sludge, caused by the valve malfunctioning.
When you are idleing, the car runs fine, it's like all of a sudden something opens up, then the revs rise and the EML goes on. Switch off, restart and whatever it is thats opening up seals, then opens again. If the petrol cap was leaking that might cause it. more investigation.
Alan.
Hi. I have the same problem with my 2014 1.2 panda. Just wondering if you managed to find the fault? We are going round in circles.I just had that off to check the o rings!. It is definitely sealing, I tried to blow through it, but is it opening?, that is the question.
What a price!.
Alan.
what codeHi. I have the same problem with my 2014 1.2 panda. Just wondering if you managed to find the fault? We are going round in circles.
