mudstuck New member Joined Oct 30, 2014 Messages 5 Points 2 Oct 30, 2014 #1 hi,clutch pipe same on 1.2 panda as 1.2 4x4 panda? thanks Mark
Matt100HP Patron member Parked in the garage Joined Jun 22, 2013 Messages 733 Points 129 Location Nottingham Oct 30, 2014 #2 No idea, but you could look on ePER and see if the part numbers are the same.
OP OP mudstuck New member Joined Oct 30, 2014 Messages 5 Points 2 Oct 30, 2014 #3 hi,Matt thanks for your reply,had a look but still not sure as not model specific enough,thanks Mark
Matt100HP Patron member Parked in the garage Joined Jun 22, 2013 Messages 733 Points 129 Location Nottingham Oct 30, 2014 #4 I can't see why it should be different, but that's purely speculative as opposed to based on any real knowledge. I'll have a look on my newer version of ePER (I assume you used the FF one) and see if I can clear it up. I assume you have a 4x4 Climbing?
OP OP mudstuck New member Joined Oct 30, 2014 Messages 5 Points 2 Oct 30, 2014 #5 hi,thanks for that,it is a 1.2 on a 55 plate( ref 169?) just 4x4 I think no reference to climbing on it.Mark
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,381 Location Norwich, Norfolk Oct 30, 2014 #6 Being a different gearbox to the 2wd it may be different.
Herts Hillhopper Patron member Written 5 guides Written a review Joined Dec 1, 2007 Messages 3,976 Points 1,080 Location North Herts Nov 7, 2014 #7 Item 1 here might suggest they are the same (so far as I know, gearbox case is same on 2 and 4 wheel drive versions and clutch actuator is same on all) http://fiat.ilcats.ru/part/vinfilte...bgroup/18103|00/var/1/rev/0/pid/14219#ddtr_01 (left hand drive car shown, so the tube is shorter here)
