Makarintosh
Member
Hey gang!
So I have added a set of new FK performance shocks to my Panda and Novitech lowering springs which was meant to lower the car by about 4cm, but I am not getting that around the whole car.
Basically, back right has settled properly but the back left is nearly 1cm higher. I have the back springs in the exact same place (ie the ending of the spring, last coil of the spring, are exactly in the same place on both sides). Do I have to keep turning the spring until I get the correct height on the left back?
As for the front, I have added both shocks and springs again, but the car is quite high at the front equally, as if they did not lower at all. Anyone else have this issue?
